Need to source T45 bolt for rear
WTASAP
12:18 AM
Moss Vale NSW, Australia
Need help sourcing Torx bolt as per images. Dealer has not been able to. Any assistance would be greatly appreciated.
Here is a German dealer. I can imagine that he has a screw you are looking for. But have a look on google. I am sure you will find one.
It does not have to be a Torx head bolt, just a bolt with the same thread pitch and bolt length. Get the dealer to tell you thread pitch, bolt size and bolt length and go to your local Bolt Shop.
It is probably easier to find the same bolt with a different head (like a hex head).
If you get the information please post it and I will add it to the INEOS Bolt Summary Table here.
Here in the US I would suggest ordering from Belmetric. They will have virtually the same bolt and finish. With that, I would order a full set for the skid plate so they all fully match.
I think the Doc is onto it if you want to get something back in that hole quickly.
The combination of Torx drive over Button Flange Head is uncommon here. M8 x 1.25 is common in the likely 15-25mm length you need. If you can accept a different drive type (not Torx) you have plenty of options.
This looks similar - if you can live with an internal hex drive (5mm hex key). Various lengths available. Example only.
The Torx M8 20mm T40 on this site appears to be the one. Unfortunately, the German supplier does not deliver to Australia (even though it does to US and SA). Pity.
I will try this strategy and post the information (if received).
