My cup tip-eth over
I find the cupholder in the Grenadier fantastic, especially compared to my LC200.
Howdy SQF1, did you ever finalize your print file for this?
This is the only cupholder mod I've been able to find that actually makes sense to me. Just replacing the cup holder and not the entire console while using the dead space underneath, very clever!
Hi! I am still running with the original design my son made. It works for me. I never really offered it for general consumption because you do have to dremel out two of the factory gussets inside the center console and part of the upper lip to get the larger cup holes to fit. I didn't mind doing that because those gussets don't seem to actually do much and other than myself, who cut them out, nobody would ever know. I can pop the factory cupholders back in at any time and all the required modifications would be covered up and unnoticeable. If you're unconcerned about doing such I can email you the files. It is hard to explain, but if you printed it out you would see exactly what I mean when you tried to get it to fit in the stock location! The files contain the cupholder, the defroster diverter I added (I'm still convinced the outragious heat from defrost is causing most winshieldcracks), and a bump out I added for the drivers seat belt. It raises the seatbelt 1/2" off the sidewall so I can grab it easier. My broken shoulders had a hard time getting the seatbelt because it was always flat against the b pillar trim.
Yeah absolutely! I've already dremeled plenty of my Grenadier so no worries haha
And great idea with the defrost-diverter, I hadn't thought about that being in Houston haven't seen a really cold day since I got the truck.
Its probably age related but those cups look about 2x my bowel size.
When I had an electric car I just coincided the charges with a toilet break. Worked a treat.
Bowel or bladder?
Reactions: Max
The nearly finished cup holder is in place. I may have him print it in grey but seeing as now this one holds what I need it to I may just go with this for a while before making any further changes. I did have to remove some of the console plastic to open up the space to fit the larger diameters. Nothing crazy and nothing that was of any true importance to the structure.
Have your son turn on "ironing" on his printer and the top surface will be much better. Or flip the assembly over and print the top surface face down on the bed.
I'll see if he has that ability. I asked him if he could flip this because the top is always so much nicer than the bed side. He said he would have to design scaffolding to flip it because his printer can't print unsupported sections and that seemed like a process. I had planned on sanding the printer marks out but in the end it works and I was too lazy to make it prettier.
And, if you could share your file in the resources tab, that would be great.
I'm functionally computer illiterate. I have a google drive link he gave me with the files but have no idea what to do with it. When people have emailed me I just send them that link. Not sure if it works that way or not.
