Luke warm heating
Will I like it? - Yep!
10:07 AM
Oxfordshire
I have a diesel Grenadier that takes forever for the heating to warm up. At its last service it had the same problem and the dealer sorted the issue.
Anyone know the procedure to resolve what may be an air lock?
Thanks for your help!
Richard
Richard
All you need to do is fill up the coolant. Both the blue and black lid with HT12 coolant, level to max on a cold engine. Some of the air has purged out and levels have dropped. It will continue doing this for the first few years until all the air has gone. It will work, not perfect but it gets hot in 5 mins from cold start in auto. No condensation or fogging.
Reactions: CRH
Exactly my experience, takes time to get all the air out if not done during manufactur
Purge the coolant system:
While you are at it, make sure the header tanks are not leaking, as they have a reputation for being 'delicate'.
Unlike fancier vehicles, the Grenadier does not have a diesel auxiliary heater or a electric heater block, (which are used to get the heater to work faster).
It actually does have an electric heater block inside the HVAC box, which I only just found out about, but how or if it works is anyone's guess...At best it would only provide luke warm air given its small size.
I saw that and thought I have never felt it working. I'll have to look at the wiring to see how it is plugged in; everyday is a school day.
Perhaps it only works when you do the front window demist?
I wonder if it’s specific to colder countries or only the diesel?
I'd have thought it was for the windscreen demist only.
I have one on my petrol version. You can see it if you remove the lower footwell panel which also incorporates the foot vents. Almost all air goes through this little electric heater, so it's not exclusively for the demist.
Maybe only works if on the highest heat setting. When I got mine anything other than full heat was cold. If the electric heater worked on the cooler setting then I would have got some warmth in the vehicle
I’ve just done some googling and this part looks very similar to a PTC heater. This is what it says:- used both in the B57 and B58 engine. We can check by finding the fuse.
  • PTC Heater Presence: The HVAC system in many B58-powered vehicles (such as the F30/F32 3/4 series and G05 X5) includes a PTC electric heater located near the blower motor to heat the air before the engine reaches operating temperature.
  • Engine Heat Management: Unlike older cars, the B58 is designed to hold heat for a long time to improve emissions. It uses a sophisticated "heat management module" instead of a traditional thermostat to manage engine heat, but this is for the coolant, not for immediate cabin heating.
  • Part Availability: OEM parts for the "power supply line PTC auxiliary heater" are listed for B58-equipped models, such as the 2023 BMW X3/X4.
  • Differences from Diesel: While some users noted that gasoline B58 engines may take slightly longer to heat up than their diesel counterparts (which have more aggressive electric heaters), the PTC heater is still standard to assist with cabin temperature.
BMW PTC (Positive Temperature Coefficient) heaters are electric auxiliary heating elements used in diesel and electric models (e.g., i3, 3/4 Series) to quickly warm the cabin or defrost windows before the engine heats up
. These, often 1.2kW–2kW, high-power components are located near the blower behind the dashboard, with common failures resulting in blown fuses.
I have a suspicion that on fan speed 4, the high frequency whine is produced from passing over this PTC high electrical current.
