leveling
Harry Wotton
8:54 PM
Connecticut
Just picked up my 2025 1925 and I'm looking for recommendation on leveling the front end. What spacers should I use and where can I find them. thank you.
Perhaps do some reading on the forum around suspension lifts on the front end and front driveshaft issues before changing anything. A small lift of an inch or less using some sort of spacer shouldn’t be an issue normally but warranty claims are being denied for driveline issues on vehicles with suspension lifts in many cases by IA so better to be informed.
Shadowmarq make spacers.or you need to spec new eibach springs.
Be aware of front drive shaft failure issues with lift. Rubber boot on rezeppa cv joint at transfer case gets put under additional strain due to angle when lifted and some have failed. Known issue. I roll stock height. :)
