Leitner 3/4 Lighting options-- Would like to see what light bars you are running
7:12 PM
Florida, USA
Tried searching but havent found anything related specifically to the leitner 3/4 rack (with safari windows). Has anyone run the onyx lightbar from baja? If not what light bar have you mounted?
-Any glare thru the safari windows?
-If the amperage is above 25 amps what have you used to deal with this?
-Crazy wind noise? Hopefully in can be mounted flush to the front of the roof rack so that it blends and should change noise or wind resistance
Thanks again for any help and if any one has some pics that would be helpful as well.
I've been looking for a while and almost gave up. How about this front roof design from Black Sheep?
I did the factory offered rhino cross bar and mounted the LED bar below it. It’s forward of the majority of the safari windows so there isn’t any glare.
Do you have safari windows? If so, how much does this light bar cover them?
Yes, I have Safari windows, but I haven’t ordered this light bar yet. According to the description from Blacksheep, 'The functionality of the Safari windows is not affected; they can still be opened and removed.'
I went with the factory mounted Rhino as well. Had to remove it due to noise. Installed the Owl hidden light bar in the grill (highly recommend). However, I.m still in the market for an overhead light bar. How's the Leitner for wind noise? Any other thoughts/recommendations?
I have the linear light bar from triple-R mounted behind the safari windows. Zero glare, extremely well controlled vertical dispersion ((this bar is popular in Europe with the rally race car drivers).
Having said that my Baja lights in the off-road light position from agile are more than enough in my book...
Got a solar blanket from overland solar 130w. Very happy with with it.
I have safari windows and this light bar from Chelsea Truck Co has been awesome. Used it driving the ski runs tonight all over Sundance. It’s perfectly shaped for front/top of INEOS. They have the same exact looking things on eBay too for like $600-$1000. Figured Chelsea would take better care of me if anything goes wrong. Little weird to install and had to relocate the internet/satellite antenna an inch or two back for it to fit but the factory hole for it worked perfectly to bring the wiring into the overhead switch panel inside.
