Ineos Website currently down and being updated
Arkaig
2:29 AM
PH34 4EL, Scotland
Hopefully so, it really couldn't get much worse particularly in terms of safe payment.
In Interior Cargo - if you add the Utility Cargo Half Height, it automatically adds the Full Height Divider as well.
Yeah, that is weird. It doesn't do it the other way around though. It is a dealer accessory so you may be safer to leave it out and just add it in when you do the final contract manually. Or buy it from the dealer as an accessory
It isn't for me?
As the 1st example ~ if I look at the Off Road options page, two items have yellow triangles:
Raised Air Intake Cyclone Pre-Cleaner *
40" Front LED Light Bar *
On the first clicking the yellow triangle pops up a box that then let's you select the necessary prerequisite ~ the RAI.
On the second clicking the yellow triangle pops up a box "we're working on it". You can't select the option until you go and pre-select the High Load Auxiliary Switch Panel but it does tell you that under either option.
It isn't for me?
That cyclone pre-cleaner is ugly as sin. Looks like an upended paint can
Well if you believe in form following function - then it's easy to conclude that it must be very, very good at it's job!
The cyclone is. a Donaldson Top spin unit you may be more familiar with the flying saucer shaped clear tops but he can type is more efficient .Made from Aluminium and Stainless with a rotating impeller inside the paint can type is 85% efficient and the clear view UFO shaped one is 75% efficient. so Ineos went with the best one if you dont like the look just get the pipe and get a UFO one on eBay not expensive but less efficient but better than nothing.
