Iced over roads- Settings for traveling in such
Rupert
#4082
4:51 PM
Dallas, Texas, USA
OK, here in Texas we are expecting some serious ice storms over and through the weekend. Does anyone have any suggestions on the settings while traveling in these conditions? I know the obvious one is to "Just stay home", but I am the only testosterone in the family (besides a neutered dog), so inevitably I am required to run errands, go to the liquor store, pick up toilet paper, etc. All that being said, would you suggest center diff locked in High, or something else? We may have some snow but sleet and freezing rain are the expectation for now. I would drop tire pressure down to 25 maybe if in agreement.
Thanks for your suggestions.
I think everyone has a different philosophy. Mine is lower tire pressure, center lock low. Your staying local and going slow so low works great.
Definitely center lock. IF you still have stock tires they are 3 peaks rated which really helps. You may find that low gear will spin the tires with too much torque. You can play with high/low to see what works best. Just keep the speed way down.
Most likely you won't need to adjust anything if you're going to be on roads. Just make sure to have a blanket and box of granola bars.
But remember, even though your vehicle may be capable, that doesn't mean the Chevy Cruze in front of you is and if they get stuck and the cars around you get stuck that means you're stuck too.
I'm in Buffalo and we've had more than a handful of storms where people had to stay in their car for 24 hours plus on the thruways because the folks around them got stuck.
Well, that would totally suck to live in a car that only has 230 miles of range with a full tank. I am sure it idles at 1/2 gallon an hour.....Great suggestion though. I wonder if I would get charged with open container if I kept a bottle of Schnapp's in there "Just in Case"!!
The way around the open container is to get a St. Bernard and give him the whiskey cask collar. Cops never check there.
Agreed and everyone to their own though. I definitely wouldn’t be using low ratio in slippery conditions if I could help it. I find higher gears reduce wheel spin especially when initially pulling away.
The other benefit of CDL engaged apart from traction is that brakes are effectively 50:50 front and rear.
The normal 70:30 (when unlocked) isn't ideal on snow and ice as it promotes front wheel lock up under braking.
Does it actually change the brake bias when the center is locked?
I find running manual is way to go when it is its slippery. Growing up in Northeast, I was taught low rpm and use your shifter. Like most of us, grew up with stick shift.
Yes, absolutely agree with this and i think a lot of people don’t realise what a difference it make - it’s really noticeable.
We’ve just been through a few weeks of lots of snow and low temps (-12C) and the Ineos was superb. High range & CDL locked - as long as the road/track was white.
Only once had to go into low range and lock the axles to recover a stuck Subaru 🤣
I would just recommend to adjust the speed to the road conditions.
CDL in my opinion is only useful when you go uphill in very slippery conditions or fight your way through powder snow.
Regarding the brakes I can not see the benefit in locking any diff.
ABS and ESP are your friends not your enemies in harsh road conditions. If you want to benefit from them locking any diff won’t help you.
regards
Max
I see your point but on ice and hard packed snow I personally find esp and abs less useful - they’re too intrusive
It always depends on the speed you move along. The faster you go the better is the computer. At least for the most of us who are not natural born rally driver. But for decent speed I am with you.
Anyway on hard packed snow you won’t have problems without locking the CDL.
Unless I cannot actually get the vehicle moving, I don't like to lock my center diff, but I also live in an area with steep hills and off camber corners and 90* grid streets that I really don't want to start an understeer slide on. To me that's the bonus of this type of case over a 2wd/4wd case which I'd prefer if I lived more south.
