High frequency vibration in steering wheel in very specific scenario
NSCU_SC
8:37 AM
South Carolina
I've had my 2025 Fieldmaster for 4 days now and have put 810 miles on it with frequent interstate driving. That should slow down in the weeks ahead, but during those trips I've noticed a very strange vibration in my steering wheel under the following conditions combined:
-Going up any incline or under load
-Between 67-71 MPH
-8th Gear
-1900-2000 RPM's
There seems to always be some light vibration at 2000 RPM's, but in the aforementioned scenario, the steering wheel becomes uncomfortable to hold after a while. It isn't like a shuttering vibration, but rather a high-pitched one that causes my hand to tingle or numb if holding for a while. Despite it being a pretty specific scenario, it's very frequent when traveling on the interstate, taking up about 40-50% of the trip when there's traffic.
I've tried to mitigate it by reducing air pressure in my tires a little, as well as got my tires rotated and balanced, but that hasn't worked. I'm going to call the service department at my dealer tomorrow to ask about it, but has anyone else experienced this or have any ideas as to what might be causing it?
I don't really notice it in the body of the vehicle, nor coming through the seat, it's just the steering wheel. If I accelerate through the speed it's fine, or if I stay under that speed it's fine. Also, when I downshift manually to 7th gear in that scenario, it goes away as the RPM's jump above 2100 to maintain that speed. I.e., I can be doing 67-70 MPH in 7th Gear at 2200-2300 RPM's and not feel anything.
Maybe check in the engine compartment for any pipe work or hoses touching the steering shaft or vibrating against it as it travels from the firewall down to the steering box.
Congrats on your new IG! I am empathetic as I abhor any sort of vibration at any speed in all of my vehicles I've ever owned.
The cheapest/easiest path is to get the wheels/tires properly balanced by a skilled technician. Hunter Roadforce it. Ensure each wheel itself has minimal to zero run out with and without tires. Once the wheel/tire variable is eliminated, then the real tricky chase is on.
Gl!
I had symptoms like this before and I fixed it by adjusting the heat shield on the side of the airbox. Open up the hood, strike the airbox with the palm of your hand, if it sounds metallic and clanging noise, then you need to bend the heat shield to the right hand side of it so that it doesn’t make a noise. Try this first.
Thanks, I'll give that a shot
I had the vehicle up to 70 miles an hour today and had no issues after seeing this post. I just wanted to see if there were anything going on there but nothing to report.
This is a known issue on a small number of vehicles including mine which is an early example with vin 193.
I had this looked at under warranty and they apparently “loosened” all fixings of the transfer case and relieved what they called “tension” on the drivetrain.
It certainly seemed much better after this procedure but certainly did not eliminate it and it has returned.
Happens all the time when under load at 1800-2000 rpm.
Good luck and please report back if you find a solution 👍🏼
I did an awful lot of heat shield remedial shaping to no avail but will now try the airbox bashing investigation 🤣🤞🏽
Thanks Forum !
Edit just noted I’m in Austria but actually “Shitake” is a NZ diesel TM so RHD 😉
p
Thanks Forum !
Here’s a video in back in 2023, me doing some airbox bashing. Diesel engine. Note at the top of airbox on the right is a metal clamp next to the heat shield. The heat shield is hitting the clamp. If yours sounds like this, then you should bend the heat shield. If not happy days. End result banging on the airbox should not have any metallic noise whatsoever.
  • IMG_5474.mov
    47.5 MB
