Hi from Kansas City!
Ordered a Donny Gray Filed master but the Mushroom has me thinking about switching. Very excited for this vehicle.
Hi thale10,
Welcome to the Forum.
At this time, If you decide to change anything on your Pre-Order, you must call the Ineos call center direct at 833-494-4748.
Here’s the terms and conditions for Changing a Configuration at this time.
4. Changing a Configuration. Once submitted, you may change your configuration prior to the Priority Deadline referred to in Section 2 above without affecting your manufacturing build slot and delivery date, by contacting the INEOS call center at 833-494-4748. After INEOS announces its Dealer Network, you may change your configuration by contacting your Dealer; however, changes to Vehicle specifications may result in a delay to your manufacturing build slot and delivery date
Here's a link to the full Terms and Conditions courtesy of @CryHavoc
Look at item 4 on page 2 to see terms and conditions for changing.
https://www.theineosforum.com/threads/u-s-pre-order-terms-conditions.12412295/post-1333184218
Even though I made a change from rock sliders to side steps after I did my Pre-Order, I will say it made me nervous about making any changes and losing my reservation build slot, even though at this time that is not supposed to happen. If your going to make any changes at this time, I recommend keeping changes minimal in regards to the amount of changes you want to do. I just did one.
Make sure to have your Pre-Order number available when you call and if you have a Reservation Number, have that available too. Make sure to get a Change Order Number from the representative to note down along with the date and time and who you spoke with.
Hi thale10,
Thanks for the info. I didn’t see side steps available in the configurator. Is that a non US thing?
You won't go wrong with MM.:)
Really? The should definitely be there.
Hi thale10,
Got the sidesteps added. They said that there will be a 2 week window to make additional changes at the end of this month without changing your spot in line.
Very difficult to see what the sidesteps actually look like and seems like a ton of money for some tubular pipe no? Thinking this will be an easy aftermarket item that I'll probably add here in the USA so haven't ordered it on my build.
