Hello from Germany, Mannheim Area!
ThomasDe
6:34 AM
Südhessen, Deutschland
Grenadier Station – Great Vehicle, But Everything Around It Is a Mess
Hi everyone,
I’ve had my Grenadier Station since mid-July. As far as the vehicle itself goes – I’m actually impressed. It’s solid, fun to drive, and built for adventure.
But everything else around it? A complete disaster.
1. The Trouble Started with the Order
I ordered a pre-built 2024 Station Wagon from a local agent. It was nearly fully equipped, available on short notice, and came with a good discount.
However, I couldn’t see the vehicle in the online order system for weeks.
I contacted customer service several times by phone, but it still took weeks until my order was finally entered into the system. In the meantime, other vehicles I had previously configured (just to estimate pricing) suddenly appeared as real orders.
I emailed customer service, explaining clearly that my actual order was the one with number XXXX – the other two were not real orders. But customer service was clearly overwhelmed. Even four weeks after delivery, the phantom “orders” are still in the system.
I followed up multiple times via email, and at this point, I’ve given up on that part – it is what it is.
2. Delivery Day: Already 7–8 Issues Before Leaving the Lot
When I picked up the vehicle – after what was supposedly a proper pre-delivery inspection – I had already found 7 or 8 problems before I even left the dealership:
  • Steering makes very loud squeaking noises almost constantly
  • User manual was in Czech – no German (or English) available at first
  • Second key was missing and couldn’t be found
  • Altimeter is off by up to 50%
  • Headliner was dirty near the driver’s door
  • Dashboard showed: “Inspection overdue by 153 days”
  • Tire pressure warning was on, even though pressure was fine
  • Cooling fan kept running long after the car was shut off – at 96 dB
    (As a hunter, it’s especially annoying – when you drive into the woods at dusk, the wildlife hears you from over a kilometer away...)
  • And later on, I also discovered water leaking through the safari windows
3. Repairs & Follow-Up – Mixed Results
I brought the vehicle back in for repairs and installation of some ordered accessories. A few things were resolved:
  • Fan now shuts off quietly
  • German user manual was provided
  • Both ignition keys are now available
But:
  • The altimeter is still way off
  • The steering still squeals like crazy
What really bothered me: I wasn’t given a loaner vehicle for the four days it was in the shop.
I paid for a fully functioning vehicle – and got one with multiple issues. In my view, it should be standard for the dealer to provide a temporary replacement while repairs are being made. But nope.
4. And Now... More Issues
I’ve had the car back for just two days – and already, new problems are showing up:
  • Daytime running lights are staying on all the time, even in “auto” mode
  • E-Call system is showing an error
Final Thoughts
I’m still curious to see how this story continues. The vehicle itself is great and has so much potential – but the service, quality control, and customer experience are far below expectations.
Honestly, it feels like customer satisfaction isn’t a top priority for the company right now. And that’s a real shame – because this car could be a true hit if the support and delivery experience matched the quality of the product.
Anyone else having similar issues?
It sounds like you have a disengaged dealer without a grasp on how to prepare a vehicle for retail sale. "Inspection Overdue" suggests a terrible Pre Delivery Inspection, (PDI) and the vehicle has been sitting around for some time.
The fan staying on suggests a DPF burn, so a feature, not a fault. It will only happen sometimes when the DPF needs clearing.
The running lights staying on can be addressed in the vehicle settings, depending on which software version you have. Again a feature, not a fault. Have a look in the manual.
The E-Call light on is probably a minor comms issue, but you will need the dealer to clear it. Some people have reported noisy power steering pumps, but squealing is usually belts. The Altimeter works from GPS and will only ever be approximate
My local dealer now has an aftersales manager. Seems obvious, but not something that many have.
By the way, daytime running lights are supposed to stay on. That's the point of having them.
I didn't think you have the option to cancel DRL, certainly not on UK and EU spec.
Hi everyone,
But:
Final Thoughts
Sorry, it is no daytime running lights. That is normal, I know. It is the Running lights and also the green control lights on the interior panel. Sometimes they are on in automatic mode under daylight conditions. When I turn them off manually and set them to automatic mode again, they stay off…
Sorry, it is no daytime running lights. That is normal, I know. It is the Running lights and also the green control lights on the interior panel. Sometimes they are on in automatic mode under daylight conditions. When I turn them off manually and set them to automatic mode again, they stay off… the noise from the hydraulic steering is not from a belt. There is no belt (as far as I know) the pump is driven by an electric motor and the noise sounds like hydraulic fluid is pressed through a leaky valve ore a pressure relief valve. The noise is annoying, because it is present all the time. When you drive through the inner city whit windows open, the sound is reflected by the houses and it is really getting on the nerves… regarding the noisy cooling fan. If it is so loud, because the DPF is regenerating, it would be ok, but it is blowing every stop, after every five kilometers it can not regenerate the DPF again and again…
Sounds like it needs a trip to a dealer for diagnosis, not a good state of affairs. I suggest you check the coolant level yourself, both tanks, as low levels would get the fans running.
I would never trust automatic on headlights, for me they should either be on or off depending on road conditions.
Noisy power steering pumps have usually been described as a whine, (the noisy MINI ones I have heard certainly were), but they have to be very loud before Ineos will authorise a change.
