Headspace roof conversion!
New accessory for the Heradspace car from Euro Flo, it replaces the ladder which cannot be used after the Headspace conversion.
Now you have a Table and Maxtrac Mini holder.
That is a nice use of space, but I'd still keep the ladder as I may have stuff mounted to the top of the Headspace, or even enter the tent from the outside.
I will be installing the GP Factor Jetpack diesel heater setup in that location. But if you don't need a heater then this is a great way to carry Maxtrax.
I went for a Propex PS2000 mobile heater since I don’t see any reason to have heating permanently attached. Stick it in the car during fall / winter and hang it off a Molle panel whenever it’s in use. Works wonderfully.
A portable heater is a good option. I just prefer to have as much as possible built in. One less case to find space for or to setup when needed. Same logic applies to portable compressors and battery banks. Build them in. It is always in the rig when you need it, has a dedicated location outside the main storage areas and simply throw a switch and you are in business. I like portable setups only when you plan to move things between multiple vehicles. Then it is ideal.
