Front Camera Warning Always on
Same problem with forward warning camera
Same problem with downloaded new map but unable to install
Does anyone with this problem- not have a winch installed?
Do all of you also find that at 9.5 km of warning lights the cruise control kicks out and can not be reactivated?
I have successfully updated my maps to the 24 new download
Very specific requirements on the size of the drive / formatting and file setup - then it runs and forwards camera is 100% more stable
All my warnings lights stays off - but then at 30 km travel my cruise control kicks off system and forward camera / stability controls and obstacle brake system lights come on - and can NOT be reset by pulling off the road and switching car off and on again
Car has to “ rest a while before warning lights can be reset / eg cruis controls and electric stability control gone for the rest of your trip
Any advice Please
These are the lights and warnings on
You might check (or have checked) that the trim piece around the ADAS camera is properly aligned. I had a situation where it was ever so slightly obscuring the camera’s view of the front hood /end of car, causing it to throw AEB disabled and other errors while still partially working depending on road conditions.
I find that a tiny amount of humidity in the morning will create enough mist on the windshield that the warning comes on. Goes away after 15 minutes of driving.
Cruise control kicks out after +_ 20 km while all warnings were off the whole travel time - then three warnings lights and can not reset the system until the vehicle has been off a good few minutes - eg fill up the tank
All weather conditions - all the time - now 2 k plus done on the vehicle and this happened on EVERY trip - cruis control on or off - after 20 km three warnings lights and all vehicles electronic stability or braking support/ hill up OD down is disabled 🤯
I drive a lot of black ice roads - this is a serious concern for me
I’ve never had that happen, and haven’t heard that situation before. Did you ask your dealer? Do you think the 20km could actually be unrelated to distance, and maybe something like the rear door latch being improperly aligned and after a while driving (just with vibration), the sensor is set off or something?
Any advice PleaseHi. give me the
Any advice Please
What are the requirements for the drive/formatting and file setup?
I never associated the camera warning icon with with ISA data. That makes complete sense. I used to think it was poor (camera) field of view.
When I had my Gren serviced in January the dealer updated the system and for the first time it actually reads the road speed limit signs! Prior to that update I got the camera telltale icon all the time, now I don’t.
