Fishing rod holders
Psignore00
2:19 PM
Apollo Beach, FL, USA
Thought I’d share this mod I found and pieced together. A couple notes to share…you will have to slightly ream the hole on the mount with a 3/8 drill bit so it fits the m10 bolt. And the knob you see in the picture wasn’t tight enough to hold them upright, so I went back to the regular nut included with the bolt.
This will fit most reels that are a 4000 size or smaller. I had to wiggle the 4000 size to get it to lock in, but the 3000 size went in much easier. I don’t use 5000 size, but 6000 was just too big
The mount also includes an adapter and u-bolts that allow it to be mounted on your ladder.
I made these for my fly rods from 1 1/2” pvc pipe with a couple of end caps and couplings, some bungees, electrical wire and duct tape. They are working great for me and I had thought of them 30 years ago but finally got around to making them.
Okay I finally got my fly rod carrier finalized. I used the Trxstle rod tubes with their clamp mounts attached to the clothes rods I modified from Amazon. It works great but only up to 8’ rods can go in it. It stops short of my Wolfbox Mirror. So it doesn’t obstruct it.
These are great. I came here looking for a fishing rod holder to go on my Leitner roof rack. The issue that I’m having is the clamp style rod holder that I have from Yakima doesn’t fit around the beefy cross bars. Has anyone come up with a solution to mount fishing rod holders to the roof racks? Thank you.
Do the Leitner Traklok bolt kits help? I plan to mount some cases and miscellany soon on my Leitner rack with a few sets of these.
That might actually work I would just need to drill out the holes on the rod holder to accommodate the bolt because right now they accommodate one with a much smaller diameter . Let me look into that. Thank you.
