Eg valve
Michael Brindley
7:47 AM
My car been at dealers all week this week for warranty work.Air con not worked since new 12months now and few other things.Engine light came on week ago showing amber not red but no faults logged in display.Garage has diagnosed egr valve faulty.New valve on order should only be few days.
If the part is only taking “a few days” then you should have it back in a month or so’s time 😂
In all seriousness I hope it is a few days, and let’s face it, stuff does go wrong, it’s how quickly they fix it that counts.
As a matter of interest, what mileage you got on the clock ??
18,300.
They have been on the air con issue for 12 months and still not there.Had to strip dash out this week.
Then theres the winch not freespooling thats going be long job.
OK, so it’s not failed with a real low mileage, it’s been used. "One of them" I suppose on the EGR.
Good luck with the rest. The AC seems to be a real common issue 😡
Don't know about mileage,wouldnt like be changing one every 12 months.
Feel sorry for dealers they can only work with constraints of Ineos and dont suppose warranty work is big money maker
Mines had engine warning light on since 26th April, EGR coupling rod being done next week & aircon & heater & door seals etc. Fingers crossed all gets fixed
New egr valve fitted today.New door seals x 2,air con fixed? So good on way home will see after couple of days.More tests on winch not freespooling and dealer awaiting instruction from Ineos.Been in twice for Winch and has failed both tests.Only problem is when got home went to fill washer bottle up and found they forgot put engine cover back on.🤬
My Grenadier also got two new coupling rods at the EGR this week. I drove with the engine warning light on for over one week. One coupling rod was already broken, the other one did its work, so that the car was still running very well...
