Display Not Turning Off
theWhiskeyRebel
6:39 AM
Houston, TX
I did a search and couldn't find anything on this, so I'll ask here -
When driving the Grenadier this morning, some of the display controls weren't responding, such as AC temp, volume, etc. About the only thing I could confirm was working was the speedo. Even the RPM cluster didn't have movement. After turning the ignition off and opening the door, the center display didn't go off. Carplay was still on the screen and music was playing. Tried locking the doors and the display remained on. I started/turned off the car several times with no different results. The same controls were still not responding.
I'm about to go out and check again after a 15 minute wait. If the display is still on, I'll disconnect the battery. However, I'm looking to see if anyone else has experienced this?
The car just hit 1,500 miles and this is the first glitch like this that I have experienced. I have the standard bi-polar AC issue and the light sensor (day / night mode on the display) is flaky which seems to be a common issue. Otherwise, no other troubles till now.
This is a known glitch. A full reset usually fixes it.
Disconnect the negative battery terminal for about 15 minutes. That should force a hard reboot and clear the error.
If it keeps happening, your dealer will need to look at it.
Thanks for the feedback - My quick search didn't show anyone else experiencing it, but I could have been using the wrong search terms?
I did disconnect the negative cable and waited a couple of minutes and everything was back to normal.
