Latest DVA Tech Article -
Everything you wanted to know about how the Grenadier's locking system actually works — Eaton E-Lockers, the Tremec transfer case, Carraro axles, engagement procedures, speed limits, the whole thing.
Quick version:
• Center diff is a dog-clutch in the Tremec transfer case. Manual says engage stationary + neutral, but owners routinely lock it at speed when axle speeds are matched
• E-Lockers: ≤3 mph to engage per Eaton, ≤20 mph max while engaged. Going above 3 mph voids the Eaton warranty
• Engagement order matters: center first → rear → front. You cannot skip the rear
• Crawl ratio is 53.8:1 (1st gear 5.25 × low range 2.5 × axle 4.10)
• The "do you even need lockers?" debate is real — some owners say traction control handles 90% of situations, others say lockers saved them towing off-road
The full guide has Eaton specs, manual vs. dealer guidance discrepancies, 15+ owner quotes from the forums, a decision matrix, and speed restriction tables: https://dvamechanics.com/blogs/grenadier/grenadier-differential-lockers-guide
Quick version:
