Americas Death wobble at 90-100km/h
constantin
2:00 AM
montreal, canada
I have a 2024 Grenadier with a post-market Fox stabilizer bar, odometer 8300km.
Yesterday, while driving on a highway at around 90-100km/h, I hit a moderately-sized pothole and the car went into a prolonged wobble, I had to use all my force and nerves to keep it straight and brake. Luckily I was on the right lane. I returned home driving at less than 90km/h, nothing happened afterwards.
Is it a case of death wobble? Solutions? I bought the car new last autumn and haven't even drove it offroad yet...
Thank you all for any infos,
Constantin
Constantin
If you have the non adjustable FOX then it's likely just a perfect storm. Get the FOX ATS adjustable and run on the stiffer side of things. Or worst case get a factory stabilizer.
People don't want to admit it but he Grenadier does have a tendency to death wobble in the right situations. I used to to joke about why Ineos chose such a heavy steering stabilizer, but I am afraid the real reason is a bit more troubling. Regardless, death wobble is ultimately tameable on the Grenadier.
High speed and rough pavement/potholes is going to unbalanced a lot of vehicles. Especially if damage has been done. I find the Grenadier actually tracks very well. It did have some issues when I was over speed going downhill and on rough payment I 70 but that’s a Colorado thing not a Grenadier thing.
Death wobble and unbalanced are two different things in my book. Unbalanced suggests the vehicle becomes a bit harder to control. Death Wobble means the truck is virtually uncontrollable outside of braking or accelerating. You are mostly just along for the ride when Death Wobble kicks in.
Reactions: AWo
Constantin
Type “death wobble” into the search bar and you will find the issue has been extensively discussed on the forum. It seemed more common a while ago when the vehicle was first launched in the US and dealers were enthusiastically fitting the fixed Fox stabilizer to improve the steering feel. It has died down for a while, probably due to the a switch to variable rate stabilizers and others just accepting the factory setup.
I think much of that also may have been from people not knowing what Death Wobble really was. Lots of people mistakenly think some minor shudders of the steering wheel is Death Wobble.
Death wobble does instil the fear of impending death.
Probably a bit like when a parachute doesn't properly deploy.
A real death wobble means something got loose at the front axle which leads to too much play.
- a bolt
- play in wheel bearings
- play because of damaged or weared bushes
Check the panhard, radius arms, steering rod, tie rod, kingpin bearing, stabilizer, steering dampee. Bushes should not be inspected just visibly but with a lever.
Of course does the Grenadier tends to death wobbles. It has a four link suspension at the front axle, like the Jeep Wrangler which also tends to death wobbles. Four link suspension do not self-stabilize. They articulate very easy with nearly no opposite force. Good for offroad driving, not so goid for street driving. They always need a stabilizer to generate force against articulation.
Cars without four link suspension can face a death wobble, as well, but Jeep Wranglers and seemingly the IG, now, sre more pronevto it.
AWo
Jon Stewart Popcorn GIF
