Has anyone else experienced a creaking sound under the truck when hitting bumps at high speeds? I notice it driving on the interstate. Thoughts?
Creaks and groans can be incredibly annoying and incredibly difficult to find. I find that a second person in the vehicle can often focus on and determine the source of the noise. Some high frequency noises reflect on hard surfaces and can be particularly difficult to isolate.Has anyone else experienced a creaking sound under the truck when hitting bumps at high speeds? I notice it driving on the interstate. Thoughts?
No mine is stockDo you by chance have lifts springs with the rubberized coil silencers installed? Under the right conditions of temperature, load, moisture and dirt/sand debris they can make a bit of a rubbery squeaking/creaking noise as the spring goes through its range of travel after hitting a bump. Either that or maybe a suspension arm or shock bushing might be the culprit.
Hmm, are the tops of the springs sitting squarely and flat in the yellow/orange colored isolator pads? It might be possible for them to shift slightly under extreme flex. The top few coils of the rear springs in particular can get very close to the side of chassis rail and could potentially rub if they have shifted in the perch.No mine is stock
My tie rod and drag link clunk around every time I brake or pulling into my driveway. Do you know how to rectify this?Do you by chance have lifts springs with the rubberized coil silencers installed? Under the right conditions of temperature, load, moisture and dirt/sand debris they can make a bit of a rubbery squeaking/creaking noise as the spring goes through its range of travel after hitting a bump. Either that or maybe a suspension arm or shock bushing might be the culprit.
Are they making contact with each other? I posted about that with a fix here. Read point 2. That's for RHD. I think LHD is a different setup but it's worth a look.My tie rod and drag link clunk around every time I brake or pulling into my driveway. Do you know how to rectify this?
They do not touch each other. They just move to an extreme on acceleration nd move to the opposite extreme when braking.Are they making contact with each other? I posted about that with a fix here. Read point 2. That's for RHD. I think LHD is a different setup but it's worth a look.
Everything is secure. I even preemptively added a bracket to support the low range shift cable. I am 99.99% sure it’s the drag line a tie rod because I have sat in the car and had someone move them. The sound is spot on. Add in the fact that I can move them to an extreme, drive straight 200 ft and come to a stop and they are in the opposite position.Climb under and have a look up and down the drive shafts. Is anything hanging low that could possibly hit it when hitting a bump? Mine was a transmission cable that had a missing mount and would smack the drive shaft coupling on speed bumps or when off road. A zip tie fixed it but it was extremely annoying until I found the issue. Mine was far from the only one to have the problem. Its worth a check.
That is helpful. I will see if that solves it.Are they making contact with each other? I posted about that with a fix here. Read point 2. That's for RHD. I think LHD is a different setup but it's worth a look.
