Bip&go @grenadier
DomK
7:00 AM
Hello,
Does anyone here on the forum use a Bip&Go for French and Italian toll roads?
If so, where on the windscreen did you attach the badge to avoid any problems?
Ideally, it should be attached in the area with black dots near the rear-view mirror, but the Grenadier screen doesn't have such an area.
Should you attach it there anyway, or is it better to attach it somewhere else? Are there any problems with the height?
Many thanks and best regards,
Dom
Hello Dom,
yes using one, will send photo later.
But I just placed it in a way that it's hidden behind the mirror as much as possible from driver's perspective. Not sure you can actually go wrong.
best regards,
P
Hello,
Dom
I use both french and Italian bip and go.. I simply put them on the back of the screen console. In that position you dont even see them, but they work well, Attached to the vertical facing the front. They are orientated vertically dead center just below line of sight,,
