Air conditioning
Luc Cornelissen
6:06 AM
France
My AC didn't work anymore. Found a tip on the forum about putting the 3 buttons to the left,......
AC works again. Been driving for 3 weeks in 30 to 40 °c and no problem.
The only thing is there is a little bit of water ( dealer says condensation water ) dripping on the drivers side.
Dealer says car needs to be 3 days in the garage to fix the dripping and to check the AC.
Anyone any experience with this. 3 days in the garage seems a bit much to me.
Some of the work needs to be done with the car from cold, (especially the bleeding of the coolant circuits).
Lagging the AC pipes requires quite a bit of dismantling - sometimes IA instruct the dealer to replace the whole HVAC box as a repair if the AC is flaky.
I've had AC issues where once out of every 6 or 7 starts I get warm air and very hot air out of the rear vents. The only way to fix is to park for 15 minutes or so and restart. The dealer told me it's a known issue but they don't have a fix. What's this 3 button trick?
This is pretty close to a "3 button trick"
"I did figure out a new fix that worked while driving. I actually turned auto off, turned the fan to the first setting, rotated to full heat and then went through all of the air direction positions and waited for the air to get redirected. Then I rotated everything to the left, hit auto again, and turned the temp to about 68 degrees. Al of a sudden it started blowing ice cold air.
I think the computer gets out of sync with the blender valves and this seemed to reset it. Hoping for someone else to validate the procedure."
https://www.theineosforum.com/threads/ac-blows-hot-on-rare-occasions.12418810/ post #6 by Commodore
Reactions: CRH
Thanks for posting this Jeremy! Hoping this works next time it happens.
It's a 3 day fix. They need to take apart the dash to get to the blending valve. It's a pretty big job.
