34” K03
any rubbing? any lift? tks
I'm running 285/75r17 BFG M/T KO3s on stock rims with Eibach lift; I also have the Agile airLynx. Slight rubbing on the top of the rear mud flaps where they intersect with the fender liner.
I tucked the mud flaps behind the fender liner to solve the problem.
Kinda bummed mine came with the 18" steelies. I enjoy 18's on a 37" tall tire, but the old rule of thumb for proper sidewall ratio is double the diameter of the wheel circumference, and that's where your minimum "ideal" ratio should be. I'll likely keep them because I am not putting any money out to swap to factory 17" steelies, I'd go aftermarket long before that. 285/70/18's here I come.
