2025 Black Friday Deals
AMAZON AUSTRALIA
The really useful Wera Tool Check Metric Plus Bit Ratchet with Sockets 39 Piece Set is 37% off. Check your local Amazon.
Metric version works best with the IG and QM.
The most used toolkit on the IG.
Look at what front springs you have now. They will have colour (color!) markings as per the above chart. If you are adding more weight you should work out the change in weight (new weight minus old weight) and go up to the corresponding amount of spring weight rating in the chart.
Example:
My vehicle was ordered with no winch and the accessory roo bar. It was delivered with green circle front springs. Another owner's vehicle was delivered with the factory winch and roo bar and it came with red circle front springs which is a +53kg rating increase (1417kg to 1470kg).
If the factory made a +53kg rating change for their winch you could also go up one rating for an aftermarket winch, unless you intend on adding more weight later then plan ahead now and look further down the chart. You only want to do this exercise once.
There should be some discarded sets of factory springs around after owners have installed lift kits. You might need to ring around some of the bigger installers like maybe AO or Owl to see if they have anything in their scrap bins. @Krabby has been chasing some through the forum classifieds but has had no luck yet.
The pinnacle of factory springs is the purple fronts and black rears. That's the heaviest factory spring combination if you want to maximise your payload capacity (within GVWR) but avoid a heavy duty lift kit.
But if I'm being honest, whilst it still seems prudent to avoid a lift and not poke the bear on driveshaft issues, there is a growing list of driveshaft failures over stock suspension that it's becoming a moot point if a lift makes you significantly more likely to have a driveshaft failure. The remaining benefit of staying with factory springs and ride height is your warranty is unaffected. That still seems worthwhile for as long as a factory warranty remains current.
Hopefully that all makes sense!
Agree
I bought my Gren without a winch, it had green dot springs. I added the GP Factor winch. I was lucky, the local shop (JC's 4x4 Denver) had lifted several Gren's, and had a pair of the red dot springs. I was adding Fox 2.5 shocks, and bought the used springs and had Jeff install them. I regained ½" of ground clearance in the front at the skid plate. Very good result.
Watch for Forum or FB posts about folks lifting their Grenadiers, and message them.
Metalcloak just put their stuff on sale, ~15% off. Ordered the sliders the first of the week and missed out!
Rola have a sale on.
Finally bit the bullet on a rack.
The best price for an ARB compressor depends on the specific model you need (Twin vs. Single, On-Board vs. Portable). Based on current sales, Northridge4x4 and TrailRecon appear to be running significant promotions (up to 15% off), with some smaller retailers potentially offering even lower clearance prices.
The following breakdown organizes the best deals found by compressor model:
1. ARB Twin Motor On-Board Compressor (CKMTA12)
Best for: Large tires (35"+), running air tools, and fast inflation.
* Best Price Found: ~$560.96 at Northridge4x4 (15% Off).
* Alternative Deal: Check Searchers 4WD Supply which showed a listing for ~$517.99 in search results, though stock may be limited.
* Standard Price: ~$659.95
2. ARB High Output Single Motor On-Board (CKMA12)
Best for: Standard tires (up to 35") and activating Air Lockers.
* Best Price Found: ~$314.96 at American Adventure Lab or ~$323.95 at ARB 4x4 Accessories.
* Standard Price: ~$359.95
3. ARB Portable Compressor Kits (In Case)
Best for: Moving between vehicles or if you don't want a permanent install.
* Twin Portable (CKMTP12): ~$900.96 at TrailRecon (Standard: ~$1,059).
* Single Portable (CKMP12): ~$412.00 at NAPA Auto Parts or similar at TrailRecon.
4. ARB Compact Compressor (CKSA12)
Best for: Activating Air Lockers ONLY (not recommended for tire inflation).
* Best Price Found: ~$212.46 at TrailRecon.
* Standard Price: ~$249.95
Summary of Recommendations
* For the absolute lowest price: The Compact (CKSA12) is the cheapest (~$212) but is only meant for lockers.
* For the best value: The Single High Output (CKMA12) at ~$315 is the most versatile for the money, capable of inflating tires and running lockers.
* For performance: The Twin (CKMTA12) at ~$560 is the industry standard for serious off-roaders.
Suggestion: If you are planning to mount this under a seat or in the engine bay, would you like me to find the best price on a mounting bracket for your specific vehicle make and model?
I have this cool tool call artificial intelligence function on my phone. I ask for it to find me the best pricing for what I need. Anyways, here
What did you use? I didn’t think most AIs would be that up to date. Interesting that it doesn’t mention the Brushless options.
Ah, seems there aren’t deals on the brushless.
I use Gemini from Google. I use it all the time to run comparisons, find info and summarize documents and presentations.
Agile Offroad has ARB on sale for 10% off:
Looks like the computers don’t get to win today
Ita all about the prompts. The original request was for arb compressor. Not arb brushless compressor. Asked again with brushless.
Best Price (Twin Onboard): ~$949.95
Product: ARB Brushless Twin Motor Onboard Compressor (CKBLTA12)
Notes: This is the flagship model. Prices are fairly consistent across major retailers (Northridge4x4, TrailRecon, OK4WD).
