Ive just clocked 111111km. Still on original tyres , brake pads & rotors.
Are you on your original front prop shaft. ?Ive just clocked 111111km. Still on original tyres , brake pads & rotors.View attachment 7913456
That would be the shocking miracle!Are you on your original front prop shaft. ?
Yes. Have changed steering damper to a bilstein unit.Are you on your original front prop shaft. ?
Thanks. Can I asked what year and month yours was built ? I’m trying to understand whether it’s just the early builds that have had the front prop shaft CV joint failure.Yes. Have changed steering damper to a bilstein unit.
Thanks. Mine was built on the 19/01/2023 and have had a few issues.Build date 05/07/23.Pick up 20/11/23.
Where is the build date?Build date 05/07/23.Pick up
You will find that on your certificate of conformityWhere is the build date?
I had the driveshaft boot rip. No lift, no off-roading (at the time) and 99% highway/surface road driving. VIN ends in 7290. US build so MY 24Thanks. Can I asked what year and month yours was built ? I’m trying to understand whether it’s just the early builds that have had the front prop shaft CV joint failure.
