Scheek-Man Vario XXL Replacement
CHM
6:29 AM
South Africa
Hi all
I need help.
I am 193 CM and the driver seat causes severe cramping down my right side (right hand drive).
I have had the bottom seat cushion replaced under warranty. No joy. I then had it padded by an upholsterer, no joy.
I am now considering dropping in a Scheel-Mann Vario XXL.
Please educate me on any considerations. It seems this has never been done.
Is this possible? I hear things about airbags and occupancy sensors. How do I get past these?
Failing this, I have to sell my Grenadier which would make me sad.
Any help on making this project work would be appreciated.
regards, carl
Hi all
I need help.
regards, carl
You could bridge the occupancy sensor and use a simple circuit to fool the vehicle that the airbag is in place.
Alternatively contact the manufacturer for a solution.
Reactions: CHM
Honest question... have you tried different seat adjustments?
My wife is much more comfortable in the INEOS with the seat back tilted back (more reclined) slightly more than in any other car we have owned.
I remember Land Rover had similar issues and there were lots of aftermarket seat rail height adapter brackets to raise the seat. Anytime like that might work. Will have to be custom made but wouldn’t be hard to do at a decent engineering shop.
Hi all
I need help.
regards, carl
It is possible but complex. You must transfer the occupancy sensor from your old seat and integrate the Scheel-Mann's side airbag into the Grenadier's system. This requires a professional auto electrician to do safely. Contact Scheel-Mann directly; they may have a specific kit or instructions for the Grenadier.
Hi all
I need help.
regards, carl
This swap is possible. The key is handling the seat occupancy sensor. You must carefully transfer the sensor mat from your original seat to the Scheel-Mann to avoid warning lights. Also, have a fabricator make custom brackets to mount the new seats to the Grenadier's rails. Use a professional to ensure the side airbag is correctly transferred. This is a known fix for comfort issues.
I understand your dilemma. I am about the same height as you and have a long inseam. The seat base does not tip back far enough for me. My thighs get very little support unless I push the seat back farther than I'd like to. I'm getting used to this, but my plan is to install a spacer under the adjustment rails at the front of the seat to tip it back a little bit more and distribute my weight across the whole seating surface, instead of just my bum.
Yes I have. Nothing has helped.
I saw a post where someone had adjusted the accelerato pedal by raising it and therefore making it more level with the brake pedal. This in turn allows you to sit straighter. I am not as tall but have the seat as high as possible (or thereabouts) and base as far back and this helps keep me a little straighter. It would be even better if the accelerator pedal was higher.
I am also adding an inverter so that i can use a mains heat pad on a support of some sort under my back. Can use in summer with aircon and not get heat from the base.
Reactions: CHM
I installed two Scheel-Mann Vario F seats (driver and passenger seats) in my 2010 Tacoma—a nice upgrade and very comfortable for long-distance driving. During the installation, I ran into two technical issues with aftermarket seats:
Passenger Side:
Managing the passenger-side weight sensor that controls automatic airbag activation. I used an Occupant Classification Sensor (OCS) from Metal Tech. This system included a manual switch that allows you to turn the passenger airbag on or off depending on whether the seat is occupied.
Driver Side:
Getting the vehicle’s computer to recognize that the new seats still had airbags (since the OEM seats did). The wiring harness under the driver’s seat contains a load transducer that signals the presence of an airbag to the computer. By installing a resistor in line with that harness, the system correctly interpreted the Scheel-Mann seats as having an airbag.
Everything worked —no warning lights, no faults, and the remaining airbags remained fully operational.
Best of luck.
Reactions: CHM
