High Air Intake question
valcor
8:53 AM
Michigan USA
When you buy the High air intake as a separate accessory, what comes with it? (Parts) how you install it? any insight will be much appreciated.
Reagrds
If I remember correctly the parts from the dealer were: the plastic intake pipe, the 2 A-pillar brackets, 4 screws to attach the brackets to the pipe and maybe 4 screws for the brackets to the A-pillar. (I'm not sure about those a-pillar screws as I might have reused the screws from the plastic a-pillar covers)
Thanks!
It's a push in and turn. A little silicone grease on the o-ring/gasket will make it easier to turn. I had to use rubber gloves to get a grip on the light to be able to turn it.
