Alternative to Teraflex Rzeppa
Commodore
2:56 PM
Pasadena, CA, USA
We all know that the factory front Rzeppa joints are the weak spot in the driveline and are subject to failure. Teraflex makes a replacement joint that can be had for about $190. It is the same joint that is used in the JL an JT. While searching for alternatives I came across a replacement Rzeppa made by Crown part number 68272524FRK. Summit Racing has them for $89. Worth keeping one on hand at that price. https://www.summitracing.com/parts/cwa-68272524frk
There are actually quite a few sources. They are inevitably all made by the same factory or at least the same town somewhere in Asia. You will notice some small variations in the backing plate it seems.
That is what I figured. Teraflex is just rebranding them. The Crown one was the only other one I found. What other ones did you come across?
