Rust (rust on wheel centres/axle ends)
Gren17
6:32 PM
Kuwait
Hi, similar to the electrical gremlins (all to date superficial[?]) there seem to be some common issues on the newly collected vehicles with surface rust on wheel centres/axle ends. My car (a sub 1000 VIN) is suffering from a mild dose of this - see below
front wheel lh
Rear wheel lh. Note it is as if the metal on centre element this side has been treated in some way ie it has a dark finish much like the front face and no/less visible surface rust? Note also rust to end of wheel bolts (this only seems to be afflicting this wheel)
front rh
Is this the same/similar for other new owners?
Hello mate, same issue with mine, did your dealership fix it and if so what was the solution? Asking for a friend
bbq4133
11:32 AM
Delaware, USA
Mine cleaned it up and sprayed some manner of rust inhibitor on it. It's a TSB.
PNW_IG
8:32 AM
Does the TSB have a number or title? My grenadier is at the dealer and want to mention this while it is being worked on.
Cheers.
bbq4133
11:32 AM
Delaware, USA
Cheers.
Not positive, but the service manager confirmed it.
4x4Brick #1561
10:32 AM
Mine also has some on the front bumper, bummer but hopefully they fix it.
I've pingged my salesman at Mossy Houston a couple of time since delivery a couple of weeks ago but no response. I have 3 out of 4 tire centers rusting and all the bumper bolts. I hadn't spray but I can. I'm just worried about the rust I'm missing that I don't see.
bbq4133
11:32 AM
Delaware, USA
My understanding is that it's the typical surface rust on the hub that exists but you typically don't actually see given the obvious (wheels/hub caps). That being said, I'd much rather have it cleaned off than not!
Norb-TX
10:32 AM
Houston
Mine too.
bbq4133
11:32 AM
Delaware, USA
FWIW this is what my dealer got to address the issue (completely forgot I took this picture, my apologies!).IMG_3701.jpegIMG_3701.jpeg
