Feeling the Buzz yet?
GPFACTOR
Supporting Vendor
6:36 AM
United States
How are the surfaces of the steps attached?
The Perforated sections of metal where their logo is located are separate plates that are screwed on. Nice because you can remove to repaint if needed, or replace with a different tread pattern if desired. Smart design.
grnamin
5:36 AM
Texas, USA
Before you tighten everything up, smear the section of the bolt that is inside the chassis with copper slip (grease) and also lightly coat the surfaces that touch the chassis.
Will do this retroactively. Thank you!
Tom109
6:36 AM
Yes, copper slip slathered on the bolts (not the nykoc nut ones) and Fluid Film sprayed between slider and chassis mounts.
UncleBuck
6:36 AM
Kent, OH, USA
I got mine installed this morning. Started out a bit cold, but then the sun showed up. :)
TWExplor
6:36 AM
Virginia, USA
Does anyone know the weight of the rock sliders? I checked the website but did not see it listed there.
TWExplor
6:36 AM
Virginia, USA
Disregard…..just looked at the OK4WD site and it lists 100 lbs total!
RyanT
Supporting Vendor
11:36 AM
United Kingdom
Global Grenadier 0076
6:36 AM
Also FYI, if you pick them up at OK in your Grenadier, you have to rest the box on the shoulders of the front seats to make the box fit and rear doors close.
grnamin
5:36 AM
Texas, USA
If you have a roof rack, you can get a mounting-a-rooftop-tent-like workout heaving the box onto your roof.
