- Local time
- 3:11 PM
- Joined
- Sep 10, 2022
- Messages
- 2,479
- Reaction score
- 8,814
- Location
- Sint-Martens-Latem, Belgium
I bought this (see below) in China (Ali Express), arrived today. Should be of good quality, because iPhones are also built in China , but only time will tell.
2800 Watt peak, means about 1400 watt continuous load.
Small digital display with both voltages (alternating 220V / real battery voltage).
Works without problem between 10 Volt and 14V (I did put it at 9 Volt, but after some minutes, it switches off).
3 universal AC outlets, two on top, one on the right side, next to the on-off switch.
Ventilator is quite noisy, but seems to work well!
95 euro. Delivery time: 11 days!
Dimension 22 X 7 X 10 cm, therefore should fit in the remaining space behind the second battery of the Trialmaster or Grenadiers with this second battery and high load power installation.
