Aftermarket Wheels List
Shinobi
12:23 AM
Abu Dhabi / New York
I have absolutely no idea if it’s correct. I have seen so many different answers. I don’t even know if the alloys are the same as the steelies.
Either way , I can fix it wheels adapters from 6x130 to 6x139.7 . This will help to have more choices to select wheels.
Global Grenadier 0076
12:23 AM
Since I may not even be able to afford one of the fine displays of engineering, I thought I’d start shopping for aftermarket parts. Here’s some offerings from Oz that’ll fit. I’m partial to the center one. I like 5-spoke wheels.
11:23 PM
North Texas
Hi folks,
I'll be ordering my vehicle with the 17-inch alloys. They are the lightest wheel (though I haven't looked at the difference in tire weight between the R17 tires and the R18 tires - but whatever the difference, it won't change my choice). But more importantly, the 17s provide for more sidewall than an 18-inch wheel, and my priority is maximizing off-road performance, not on-road performance. In practice, the difference between a 17 and an 18 on-road won't be that noticeable (a little frmer handling in the corners with the larger wheels). Because the tires are not all that large, I think the difference when airing down (off-road) between a 17 and an 18 is more significant than the difference on road (but again, not an enormous difference). So that's my logic (i.e. what makes sense for my particular driving).
I've got a couple of questions about wheels, and I'm hoping someone can help.
First, I've seen this table posted (below), but I'm not sure where its from. I have the U.S. Brochure, and its definitely not from that document. Does anyone know where this can be found?
Second, are the alloy wheels forged or cast? If you have the answer, could you also post the source.
Thanks in advance!
I don’t see if the answer was provided to the cast or forged question, does anyone know? Thanks.
12:23 AM
Alprider
6:23 AM
Courchevel
in the website mentioned PCD 6x130, is it correct ?
Does Inoes Grenadier PCD 6x130 or 6x139.7? and what is the ET?
very important
6x130 and 45 offset for the zero's I have 4 18" on the way!
MMICHAELS
11:23 PM
HOUSTON
Just bought 5 Black Rhino Yellowstone gunmetal I'll keep the steel rims laying around. When the first round of tires wears out maybe a 285/75 R18? I'm not forking out the cash for the INEOS Rims - geeeeeez. This felt in the right spirit?
DaBull
9:23 PM
California
Hi MMICHAELS, Very nice looking!
Looks like a Grenadier 17" alloy and a Grenadier 18" alloy got together and had a son.
DaBull
IG_LA
9:23 PM
Los Angeles, CA U.S.A.
I've checked out these wheels before. When I go to Black Rhino's website it says there's nothing compatible with Grenadier even this one. Where'd you purchase these??
DaBull is correct but these are nicer IMO. I'd put 275/70/18 as more than enough clearance for anything.
1:53 PM
South Australia
I have already got the black rhino Yellowstone rims with Yokohama 295/70r17.
Rims size are 17x8, 6/130, 84.1 bore, 38p but also available in 45p, and in 18s with the same specs.
the rims are very strong, rated for 1500kg each.
IG_LA
9:23 PM
Picture please.
MMICHAELS
11:23 PM
HOUSTON
www.customwheelsexpress.com/custom-wheels-by-brand-black-rhino-black-rhino-1pc-cast-black-rhino-yellowstone-matte-gunmetal-custom-truck-wheels-p-5907.html
1880YWN486130G84 6X130. 6X130 45mm offset - I solved the fit problem by buying them on a website that doesn't ask for a vehicle. Let's see if I am lucky!! I'm basing the it will fit on the fact Steve B, has them AND it looks like the bolt pattern and offset are good to go. I'll know in a few days.
12:23 AM
When you're looking around, you can search for Sprinter wheels as they're also 6x130 .
IG_LA
9:23 PM
OK! I'll be buying these too then.
If it fits our truck, why wouldn't Black Rhino make it available for us to purchase? @Steve.B
IG_LA
9:23 PM
For the 17s should have an offset of 38 or 45 or either or?
Is there a big difference from 38 to 45? If so what are the advantages and disadvantages? Sorry, just trying to learn these setups.
Loc Nar
11:23 PM
Alabama, USA
Method MR706s installed with winter tires. Working well.
Looks great, but if you would be so kind as to indulge me, I'd love to see some profile pics in daylight. I ask because I ordered a set of those as well. Hard to beat the $200 per wheel markdown price!
IG_LA
9:23 PM
1880YWN486130G84 on the website is for the 18s with an offset of 48. Was that a typo?
Latest posts
