Introduced here:
https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333369436
2024 ( Petrol ) Ineos Trialmaster with ( OEM ) RED integrated winch
We’ve added the following components over the last year ( most of which occurred over the last few weeks ):
Alu-Cab Silenus RTT - Replaced the roof grab rails with black ones from GrenadierUSA and upgraded the struts.
Make sure you request the “heavier load” ( 500N or 800N ) struts if you’re going to put load bars, solar panels etc.
on the RTT…
Alu-Cab Shower Cube
Alu-Cab 270 Shadow Awning with Alu-Cab awning gutter
Alu-Cab Molle Panels for Joolca ( HOTTAP pumped hot / cold ) water system and
Propex ( PS2000 Portable ) heater on driver’s side with VAAST 18L water tank on passenger side.
ROAMRest custom mattress for the Silenus RTT - HEST stuff for bedding since they’re close to us
300W Solar Array ( 6 x 50W Sunflare XPLOR BLOX panels )
Buzz Overland Big Brake Kit ( red of course ) along with Buzz door steps
REDARC BCDC ALPHA50 12V 50A DC Battery Charger
REDARC ALPHA150 12V 150AH Lithium ( Auxiliary ) Battery
LRA ( Brown Davis ) Auxiliary Fuel Tank
Braid Fullrace T Dakar Wheels with ( Agile Offroad ) Apex RPV + TPMS brackets
Victron Orion-Tr 12V / 24V 5A Isolated DC DC Converter - Used for Starlink Mini via external mini-Anderson.
LETECH Multi-Function rear ladder - We’ve put another 18L LIFESAVER Jerry for water in this location.
Ineos ( OEM ) Roo Bar
Wolfbox G900Pro rear view mirror with 67Designs mount since the rear is packed with gear.
Ineos ( OEM ) front and rear “black” springs - We’re thankful to the forum experts for documenting the
relevant model numbers since we didn’t have access to the Ineos tech portal when we ordered them.
GrenadierUSA machined center console ( looks cool ) and cargo wall L-tracks.
GP Factor folding tailgate table and Starlink Mini mount - Powered through external mini-Anderson
port on the driver’s side ( seen below ).
Agile Offroad’s ARB Onboard ( brushed single compressor ) Air Kit ( under rear seat - plumbed into the back )
Abenteuer 4x4 Rock Sliders - Wanted to minimize any loss of ground clearance or change in ramp angle.
REDARC Tow-Pro EBC - Mounted under rear bench seat with dial adjustment in center console.
Guzzle H20 ( Stream ) water purifier
GrenX Aluminum Snorkel System with Sealed Airbox ( OEM styled variant ) - leaning towards a Volant Donaldson
PowerCoreG2 ( pod ) air filter in this setup since we’re planning on a fair bit of desert travel next year.
Other bits:
Rosen visors and SUMA ( convex ) mirrors from Owl - wanted these for the Molle panels.
Black Sheep Innovations display sun visor for the head unit - Seems to minimize the glare a bit.
Agile Offroad ( Baja Designs ) offroad grill lights - AUX1 with dimmer support at the moment
We wanted to leverage the existing Auxiliary ( offroad ) lighting switch since it no longer serves any purpose…
Baja Designs ( passenger / driver ) scene lights ( 2 x S2 Sport ) - Switched externally since these
are powered through roof mounted DTPs - @Loc Nar’s post [1] was inspiration for that feature.
Baja Designs reverse lights ( 2 x S2 Sport - attached via Leitner Designs chase light brackets )
GME GMRS ( compact ) radio setup with KAON LHS ( driver side ) antenna mount
Forgot to mention:
Goose Gear CampKitchen and rear plate system ( driver side ) - We’re running a National Luna Legacy Smart 50L
fridge / freezer and Cook Partner 22” ( 2 burner ) stove within the CampKitchen module.
A few bits from the Grenadier Works store too ( the rear door handle is awesome ) - Console mounting bracket for
a 67Designs tablet mount, license plate light shrouds, map light glare shields, rear door handle, and L-track accessory nuts.
No doubt other stuff I’ve failed to mention…
[1] https://www.theineosforum.com/threads/work-light-on-roof-grab-bar.12415826/post-1333313533
on the RTT…
Alu-Cab Shower Cube
Other bits:
Forgot to mention:
