Phone holder
Have just purchased a quartermaster 24 model dual cab - looking for information on quadlock mounts for phone. Also any information on tray manufacturers Victoria, Australia that people can recommend.
Speak to GrenX or Norweld for a tray. Look here also.
Welcome aboard. Some useful links here:
Part 1
Part 2
AU Vendors
From the AU Vendor list
QUARTERMASTER UTE CANOPY/TRAY
  1. NORWELD has trays, full canopies, half canopies and compact canopies for the QM here;
  2. Trig Point has a canopy for the QM here;
  3. GrenX has tray, canopy and RTT here;
  4. MW Toolbox Centre QM has a full canopy without a tray here;
  5. DMW Ineos Deluxe Alloy Tray here, with a compact canopy;
  6. For other countries look here; and
  7. Shade Trim Canvas (STC), on the Sunshine Coast Qld, has made a Ute canopy for the Quartermaster, pictures here.
Phone Mounts below, look at item 3 for Quadlock.
Phone Mounts
  1. The HoldMyPhone plastic bracket (the same products available in USA at ProClipUSA and on Amazon under the name Brodit).
  2. Similar products available from Get Good Gear here. The GetGoodGear aluminum bracket can be used to mount a GME Mic, RAM Mounts, Quadlock, etc.
  3. More4X4 Quadlock Mount here.
Download a copy of the Rok Dr Guide and keep it in the car:
someone posted a diy one on the Fb group made up with a bunnings QL mount, picked up the screws of the seat heater switch panel, could probobly be adapted cutting a hole in center for those with heated seats. actually lookid pretty smart, personnaly i would billett file it , use cap heads and hit it up withe some Annodise finish paint
Another phone Mount
GGG Accessory Mounting Plate for GME Mic, RAM Mounts, Quadlock here;
Found this one on Amazon, MagSafe charger included... Doesn't block airflow to passenger, seems pretty sturdy.. I don't generally like vent mount but this isn't too bad apart from being very tight to get the hook in and out of the slats (ie you have to flex the vents) $59aud with the 12v adaptor so a bit exxy for an Amazon item but nicely made
It looks fragile, just my $.02. I would start with a Tiny Rig device holder that replaces the plastic trim below the vents.
You need to redo the video, you are not wearing your Fez.
Matt Smith would be shocked, shocked I tell you.
I only wear my few for "Uncle Fezzy's crappy commercials" that and that stupid thing is hot. It's actually "real" so it's like 1/4 felt and almost as bad as wearing my tinfoil hat
