What's on the horizon for Ineos?
Ineos Automotive chief executive Lynn Calder ponders future opportunities for the maverick 4x4 manufacturer
www.carmagazine.co.uk
Interesting comment![]()
Ineos Automotive chief executive Lynn Calder ponders future opportunities for the maverick 4x4 manufacturerwww.carmagazine.co.uk
My basic Bluetooth dongle to my phone works on the Grenadier.The only communication that I would really like from Ineos at the moment is to be told where I can buy a handheld fault code reader that will plug into the Grenadier. Once I have that they can maintain radio silence as far as I am concerned.
Thank You - I will give it a go - I have had that irritating orange engine icon for a week or so - it only normally lasts a few days - might be able to wipe itMy basic Bluetooth dongle to my phone works on the Grenadier.
It can read a whole range of sensors.
The only real error I have had was when one of the egr rods broke, it reset that code. It doesn't reset the service warning.
If yours is a diesel it might be the same as what I had. The original pushrods on the EGR can crack and flash up a code.Thank You - I will give it a go - I have had that irritating orange engine icon for a week or so - it only normally lasts a few days - might be able to wipe it
Thanks will try basic self diagnostics - booked in for a service on Feb 3rd with Compass so will get them to check then if no joy earlier - having all my sticky locks replaced the as well. Funny things - all five of them stick when the weather is damp and the temperature is in the 40 to 50 F range. All work fine if the air is dry or if the temperature is below 40 or above 60 degrees. Working a treat now with the temperature at about 25.If yours is a diesel it might be the same as what I had. The original pushrods on the EGR can crack and flash up a code.
If using excess Adblue then it's definitely brokenIf yours is a diesel it might be the same as what I had. The original pushrods on the EGR can crack and flash up a code.
If you haven't had the door buttons already replaced then you probably haven't had the EGR pushrods done either.Thanks will try basic self diagnostics - booked in for a service on Feb 3rd with Compass so will get them to check then if no joy earlier - having all my sticky locks replaced the as well. Funny things - all five of them stick when the weather is damp and the temperature is in the 40 to 50 F range. All work fine if the air is dry or if the temperature is below 40 or above 60 degrees. Working a treat now with the temperature at about 25.
Plugged in two different diagnostic tools in the workshop - old hard wired one and modern blue tooth one - both picked up the Vin number but would do no more. Net result of plugging them in is that I now have the nice little orange warning triangle with an exclamation mark in it on the bottom right hand corner of the display to keep the orange engine warning light company. Assuming neither go red I will wait for the service in a month to sort.If you haven't had the door buttons already replaced then you probably haven't had the EGR pushrods done either.
