Had my KO3s put back on and installed on some spare rims, so I had to get new TPMS sensors. They had the ‘Alligator’ brand model AU591134TQ12T10. Originally, they just had the rubber valve stem, but they had some metal stems like the OEM, so they used those.
All the sensors seem to link up but:
I’m not sure how accurate the reporting is to the IG display
One of them is reading 36psi, even though gauges say it has 45. As the tires heat up, it does change, so it’s not stuck.
-The value stems have weird caps on them that seem to have a ‘vent-thru’ feature, they are Dill 6541 caps
The weird thing is that the low tire is the driver rear, but when I start up the car, the passenger side rear reads low, but then it switches? The pressures actually swap.
Going to get out with my best gauge and my icheck deflators and my new ARB compressor and cycle them up and down in pressure to see if that is the issue.
-Are the blow-thru caps a good idea? I’ve never seen them before?
-Are those the right metallic stems? In the alligator manual there are a bunch of different versions and instal modifications. What is the correct install according to this manual??
Thanks!
Thanks!
