Arguing on the internet is the equivalent of talking to a wall. I made a statement based off the OP concerns and you don't agree. Great, agree to disagree and let's move on and stay on topic.
Thanks for validating my criticism of your posts.Arguing on the internet is the equivalent of talking to a wall. I made a statement based off the OP concerns and you don't agree. Great, agree to disagree and let's move on and stay on topic.
Pretty sure most of your questions could be answered by using the search button as this topics has been discussed before. Try it!Was anything significant changed in MY25 vs. the later MY24? I know of the sticky button issues and door seals in the early MY24, but with a 5 year/60k warranty, buying used might also be appealing.
Sure, as long as your opinions and statements are supported by evidence, facts and documents. Try it sometime...LC0013, can you stop harassing people just because our opinions don't align to yours.
You wouldn't know if evidence were to smack you in the face mate. Give it a rest, smoke something stronger.Sure, as long as your opinions and statements are supported by evidence, facts and documents. Try it sometime...
And again, it is rather ironic that you cannot stay on topic.
Send me a PM so you do not continue to clutter up this thread.
? ? ?Make sure the HVAC setting are set before starting the engine.
Example:? ? ?
I find auto is rubbish at giving the footwell some heat. A few times I have found my legs getting very cold and switching to manual resolves it.I never use Auto. The few times I tried it, it went bezerk! I’m much more comfortable making small adjustments in manual mode. I start the engine with everything off, then turn on as needed. I turn everything off, then shutdown the engine.
Mine also works fine.
I believe it was easier to launch the space shuttle....Example:
If it is warm.
Insert key
Turn key on without starting
Auto button pressed and lit
A/C button pressed and liwarm t
Select Vent and floor zone
Temperature set to one click above "C"
You have now done your base settings for using A/C
If too cold turn temp one or two clicks toward the right (warm).
You don't need major changes. Use small control changes.
If you are warm make sure Auto and A/C are lit.
Move temp towards the right.
If it is a cold day start out with Auto button lit, temp straight up and A/C off.
Set both the 2025 and the 2026 the same before strting the engine.
I am making it more complicated than it is to make a point... setup HVAC base settings then make small changes.
Thanks...
If heating is not consistent the cooling level was never checked and purged my the dealer.
It is a great system ounce you understand it.
Again... initial setting before starting the engine. Then small adjustments...
If you are cold move t
Most people just find that it is easier to complain about.I believe it was easier to launch the space shuttle....![]()
